| speakers from the headunit. If you went with a separate amp then I would consider running a larger gauge wire to them. Assuming whoever installed your headunit used a harness like this and didn't just hack into the stock harness, you can use the speaker wires as labeled.
RTFSM - Read the Factory Service Manual Purpose of site is to archive Z information. It is found by using search. Same reason you go to a library to read books to research a topic instead of standing in the library lobby shouting your question hoping someone has read the books your answer is in. - LordZ Hi guys, my mechanic died before finish my car so i try to finish myself - ktranne |
